+ Reply to Thread
Results 1 to 17 of 17
Thread: Chain or timing belt? 1.3cdti
  1. #1
    Hi guys,
    Do the diesel engines run on a timing belt or chain? if a timing belt how often should i change it?
    If its a chain do they need changing like a timing belt?
    Sorry if it sounds obvious.
    Would appreciate it if anyone could help.
    thank you
  2. #2
    Falkirk
    I'm sure its a timing chain mate and it does not need changed. Correct me if I'm wrong though folks.
  3. #3
    any other takers on this one?
  4. #4
    Falkirk
    Bout 95% sure btw mate.
  5. #5
    Moderator
    Spring Feature Car
    Liam's Avatar
    Stockton On Tees
    Timing Chain
    Corsa Gone
    Banana Power Here!
  6. #6
    In A house near the water
    tis a chain, it should never need changing but..............
  7. #7
    my 1.3 has a belt tho? 07
  8. #8
    peterlee
    chain and they do advise at 100,000 or 150,000 cant remeber but the z13dt and z13dth are deffo chain, and there a CU*T to do
  9. #9
    East Lothian
    Quote Originally Posted by 078_devitt View Post
    Ive no worries there mine will be long gone before it gets anywhere near that sort of mileage
  10. #10
    is the chain visiible from the engine bay? i can see a belt like my old pettrol had
  11. #11
    Portsmouth
    Quote Originally Posted by philsxi View Post
    im pretty sure the belt you can see is the auxillary belt that runs water pump, power steering and a/c if you have it. the chain itself is under the cam cover and cant be seen without removing it, but correct me if im wrong some one.
  12. #12
    ok well that does sound about right, is the auxillary belt possibly causing the squeeling i get when you turn on the engine and when accelerating?
  13. #13
    Portsmouth
    is it a squeeling or more of a dull whine? if its the whine then thats normal, well mine does it and so does my mates corsa thats chain driven.
    If its the squeeling then yea probably the aux belt, one of my other mates cars does it, usually just needs tightning up and sometimes the belt and or tensioner needs changing but seeing as its a new car a tighten up would probably do. a local garage would be your best be for a tighten Vaux will probably tell you its something really major and charge the earth for it
  14. #14
    thanks for the advice, im going to get it booked into a near garage and hopfully its just a matter of tightening the belt
  15. #15
    Nr Swindon
    What about for the 1.7?
  16. #16
    Portsmouth
    Quote Originally Posted by Channel_5 View Post
    got a pic of your engine bay you can post up, or can u take one to post up?
  17. #17
    peterlee
    Quote Originally Posted by corsad1989 View Post
    belt
+ Reply to Thread
