Squealing Noise Coming From My Engine ... HELP!
+ Reply to Thread
Results 1 to 15 of 15
Thread: Squealing Noise Coming From My Engine ... HELP!
  1. #1
    Essex
    Has anyone else had this problem???
    The other day when i was driving my bf told me that he could hear a high pitched squealing sound coming from my engine, he said its been like that for a while (but forgot to tell me ) does anyone know what this could be?
    Administrator icy's Avatar
    Rochdale Lancs
    Prob either a lose fan belt or aux belt, any garage can fix this quite easily, might even just need retensioning.
    60 Arden Blue Corsa VXR STOLEN
    RIP BINGO999
  4. #3
    Erith
    i get a squeeking when its warm and below 2000rpm, but above that (which it is most of the time) its fine, does that sound the same as ur sound??
    Essex
    Quote Originally Posted by little-jt View Post
    Yehh thats exactly my problem, do you know what it is? x
  7. #5
    Rochdale Lancs
    RIP BINGO999
  8. #6
    Essex
    Thats the one!!
  9. #7
    Administrator devvo SRI CDTI's Avatar
    Chesterfield
    aux belt / fan belt slipping will prob be worse when u put ful lock on if its not electronic power steering
  10. #8
    Rochdale Lancs
    Should be a fairly cheap job to fix, basically either your fan belt or aux belt is too slack, sometimes they can be retensioned but in the past I have always had them changed as soon as I hear them squealing
    RIP BINGO999
  11. #9
    Erith
    vx told me my belyt was fine and they'd look in2 the problem further when it goes for a service :\
  12. #10
    Rochdale Lancs
    If it is squealing then it isnt fine, at the very least it needs adjusting.
    Just be aware that belts wont be covered under warrenty so is likely to be cheaper to look at a smaller independant garage to replace the belt, its not a big job.
    RIP BINGO999
  13. #11
    Ingleton, Carnforth
    You know Vauxhall... They'll tell you anything to make you happy.
    If it needs replacing or adjusting then get it done. Loose belts can cause massive damage.
  14. #12
    Erith
    hmmm, adivce taken, i shall giv erm a buzz 2moz, essexbrunette, do you have a 3 door in red??
  15. #13
    Essex
    hmmmm im gonna look into mine asap then! cant afford for the engine to go wrong! naaa got a 3 door in silver how comes x
  16. #14
    Erith
    i rang vx today, got mine booked in, and i was over in essex yesterday and sat behind a 3 door 1.2 iat standstill, had exaclty the same squeel as we do, sounds like its gunna be a common issue.
  17. #15
    Erith
    Got my car back from VX yestersday, it was the coolant pump bearing, they were nackered, and thw whole unit needed replacing, otherwise it would of ended up failing, so I'd get it checkd out, better to be safe than sorry
+ Reply to Thread
