Frozen Windscreen :(
+ Reply to Thread
Results 1 to 25 of 25
Thread: Frozen Windscreen :(
  1. #1
    Huddersfield
    Does anyone know how to stop the Inside of my windscreen from freezing up?
    I thought on new cars this shouldnt happen, but it does everyday!
    Swadlincote
    Mine too, well mainly when I breathe when getting in the car/slighty warmer air hitting the freezing windscreen probs does it.
  4. #3
    Chester, Cheshire
    Mine does this too, its soo annoying as if you start scraping you get covered in ice inside the car lol!
    Banned User
    c(:|
    if you open your windows for 5 minutes before the end of your journey the air inside the car will obviously be cold like the outside, therefore it wont cool down and freeze to your windscreen
    its freezing because the air inside the car is warmer than the air outside (beacause of the heaters obviously) so when this cools, you get condensation, then you get ice
  7. #5
    Spring Feature Car Liam's Avatar
    Stockton On Tees
    Never had ice on the inside of mine
    Corsa Gone
    Banana Power Here!
  8. #6
    Banned User
    c(:|
    show off
  9. #7
    Stockton On Tees
    :lol: Look after my car she looks after me :lol:
    Corsa Gone
    Banana Power Here!
  10. #8
    ROBIN HOOD's Avatar
    Nottinghamshire
    Try putting some old carpet or similar onto the screen once you have parked up for the night, that should insulate both inside and out.
    This has worked for me for the last couple of nights.
    R.I.P.
    PAUL BINGHAM 1985-2012
  11. #9
    Banned User
    c(:|
    Quote Originally Posted by ROBIN HOOD View Post
    this!
    + make sure the inside of your wind screen is clean as well
  12. #10
    Chester, Cheshire
    I use a flattened box across my windscreen when we have a brewery order delivered!
  13. #11
    Stockton On Tees
    Clean your windscreen often, i do and mine dont freeze and hasn't done yet
    Corsa Gone
    Banana Power Here!
  14. #12
    Huddersfield
    Quote Originally Posted by Pew View Post
    i have tried that, i opened the doors to let all the cold air in, still froze over.
    its awful i just sit there with the heaters blowing on it for 10minutes.
    Tonight i just moved my mums car out of the garage and stuck mine in so it'll be fine tomorrow!
  15. #13
    Leeds
    Mine only freezes inside where I haven't cleaned it very well, lol.
  16. #14
    Huddersfield
    Quote Originally Posted by Nick View Post
    what do you clean yours with?
  17. #15
    Banned User
    c(:|
    i just use glass cleaner, same stuff i do the windows in the house with
    seems to work fine
  18. #16
    Huddersfield
    oh right, i'll have a go sometime!
    cheers guys!
  19. #17
    Milton Keynes
    Haha good ideas, sound obvious until you do them
  20. #18
    Leyland, Lancashire
    I've found turning the heater control all the way to the left when l park up tends to help.
  21. #19
    Corsa D Challenge Moderator JaseWW's Avatar
    Colwyn Bay
    Dont spit on the inside of your windscreen when you talk!
    Mines never frozen so i dont really understand
  22. #20
    West lothian
    mine was doing it aswell. but found an idea for that. Mind You got a wee bags with small balls inside whch is absorbing a damp from air when You buy new trainers? (just an example) Well my misus working for bic electronic company and they got deliveries with silicon blocks. In the boxes are the same bag witha that small balls inside but alot bigger. two on a back and two under a seats and job's done. absorbing everything and works really well. Car probably is damp inside. There's a couple of reasons. Main is when U get Ur car mats they are absorbing every drop of water, snow and other s**t from Ur boots. When U turn a heater on (as I do aswell for legs) that starting water to evaporate and U got steamy windows inside. With connection with freezin temp's outsiedce U got frozen windows inside.
    Sorry for boring post but i think it answered most questions. As someone said also helps when U turn heaters to cold short before U end Ur journey.
  23. #21
    Hertfordshire
    i always thought it happened when there was damp inside your car ie your carpets or matts from your trainers. or i remember it happened on corsa c's when rain leaked into the passenger footwell
  24. #22
    bournemouth
    its called silica gel and yeah you will need quite a bit of it lol however if you buy a cheap biscuit barrel in the lid they have it and u can take out the metal thing that holds it and yeah just whack it under the seats or summat
  25. #23
    Glasgow
    Mines has only ever frozen inside once, found it strangely funny at first, freezing inside.
    Didn't find it so funny after I started driving and it started melting and all the condensation ran down the window and i couldn't see feckall :lol:
  26. #24
    Wigan/Manchester
    the silica gel thing sounds a good idea as i agree with the above about damp getting in due to snow on feet etc then its all condensation freezing etc...
    does anyone know how long the little bags last?
  27. #25
    winsford, cheshire
    A long time depends on humidity , extreme temps etc
    It constants absorbs & de sorbss depending on water vapour
    All I know is you can re use it by putting it in the oven at 150degree to re dry it out just the beads not in the sachet lol
+ Reply to Thread
