corsa wont start sometimes
+ Reply to Thread
Results 1 to 14 of 14
Thread: corsa wont start sometimes
  1. #1
    southampton
    sometimes the car wont start after use. if was driven for 4miles left for 20mins and started back up it would stutter for abit then start. oil's ok all the usaul lights are on electrics ok petrol is half way. if i stop it then try again it goes straight away and will be fine untill the next time.
    Oxford
    How old is the car??
    Could be a loose connection.
    Maybe your battery is about to die?? Battery's don't like short journeys. It take about 10 miles of driving to recharge the battery fully after starting.
  4. #3
    Trader
    Standard Product Trader
    stampede's Avatar
    How old is the car?
    southampton
    july 09 plate
  7. #5
    Spring 2011 Feature Car
    Malta Organiser
    balz's Avatar
    Malta
    maltese corsas suffer from this too
  8. #6
    southampton
    done it 2x today aswell :/ got some redex im gona flush through tomorrow hope it clears the tubes up
  9. #7
    Malta Organiser
    balz's Avatar
    Malta
    opel say its normal
  10. #8
    southampton
    dont sound it lol like its starting on a empty tank
  11. #9
    Trader
    stampede's Avatar
    BCM fault is my guess.
    Does the yellow spanner light flash when it fails to start?
  12. #10
    southampton
    erm i cant remember but last i remember i went normal ( i.e normal lights glowed) whats a BCM fault btw
  13. #11
    Trader
    stampede's Avatar
    Body Control Module.
    Common problem on Corsa D/Grande Punto. Car sporadically doesn't start and yellow spanner light flashes. Eventually doesn't start at all and B1000 "replace ECU" code set in BCM. Needs reprogramming with the latest software and keys re-pairing, if that doesn't work, BCM must be replaced.
    I don't know if this is your problem or not. Check for the flashing spanner light next time it happens.
  14. #12
    southampton
    not major like gasket is it? need it for work lol so when i start it up i just got watch the spanner and see if it flash's or not. would a remap have effect on this?
  15. #13
    Trader
    stampede's Avatar
    It's one of the control modules, and part of the immobiliser.
    Remap won't make a difference.
  16. #14
    southampton
    ok thanks for the help and info stampede.
+ Reply to Thread
