Heater Resistor Location?
+ Reply to Thread
Results 1 to 13 of 13
Thread: Heater Resistor Location?
  1. #1
    LIVERPOOL
    Ok so I'm having that problem where my blower only works on setting 4
    Does anyone know how to get to the resistor? I've read that the heater motor is behind the glove box which is easy enough to get to, is the resistor in the same area?
    Help will be appreciated.
    Birmingham
    I had the same problem 2 weeks ago
    Take the glove box out
    get on your back in the footwell and look up
    You will see a cable popping out of a unit.
    pull it out and replace
  4. #3
    LIVERPOOL
    Cheers mate will do. Some people have said just taking it out and putting it back in has worked. I'm not that hopeful, I've had a nightmare with my heating system recently. Had a cracked heater matrix over Xmas and blowers were spewing coolant into the car. Sorted that though.
    Oh well will find out tomorrow.
    Leyland, Lancashire
    Check the wiring too, there have been cases of the wiring burning out too. Although usually is just the resistor pack.
  7. #5
    LIVERPOOL
    Cheers will check today and see if I need a replacement
  8. #6
    LIVERPOOL
    Well I took the glovebox out but couldn't see it. Do I have to take the heater motor out as well?
  9. #7
    Leyland, Lancashire
    No mate, should be to the left of the heater blower motor. Trace the wiring back and you shouldtfind it.
  10. #8
    LIVERPOOL
    Well I think I've found the cause of the problem anyway. The loom going to the resistor is dodgy. I unplugged the loom and plugged it back in and it worked lol. I'm not going to get this changed though just yet. If it just requires a wiggle every now and then a not that bothered.
  11. #9
    dumbarton
    i have the same problem i have to slap the side of the dash for it to work lol
  12. #10
    Removing blower resistor help!
    Hiya,
    Brand new to the forum - just wondering if anyone can help me with sorting my blower (which currently only works on 4)
    I am currently trying to get to the resistor to replace it: I've done the follwoing:
    1 - Taken out electrical plug
    2 - Unscrewed the 5.5 millimeter bolt head
    I can see the black unit has two plastic clips one on either side, but no matter what I do I can't remove the unit/get it to come out! Can anyone help/tutorial - anything?!
    Thanks a lot
    Mike
  13. #11
    Can anyone help me with this?! It's driving me mad!
  14. #12
    Scotland
    Sounds like it might be burnt out and melted into the wiring housing
  15. #13
    The unit itself feels loose and there is some movement, so not sure if its burnt out - the only problem is I can't seem to remove the unit itself from the housing after taking the screw out - I know there are some plastic tabs on the bottom of the unit itself but pushing/pulling these seems to have no effect. Can you help me out and tell me how to remove the unit itself please, it would be much appreciated!
+ Reply to Thread
