Knocking/clunking sound from drivers side back wheel
+ Reply to Thread
Results 1 to 12 of 12
Thread: Knocking/clunking sound from drivers side back wheel
  1. #1
    Chester
    Hi guys,
    Looking for some help. I have a 2007 1.4 SXI and recently (within the past 2 months) i've noticed a knocking/clucking sound which seems to come from the drivers side back wheel. Its more noticeable at low speeds, especially going over bumps. It can sometimes be there and sometimes not. More often its there and it seems to be getting increasingly there. Its one of those sounds that you can't describe to anyone. I've tried to tell my dad, but I can either not describe it, or the sound isn't there when he's in the car, annoying! I know its there and I know its been getting worse as I drive the car every day.
    I've had the wheel off and checked over the wheel, suspension and shocks, but can't see anything apparent?
    Anyone have any ideas what it could be?
    Thanks!
    Alex
    Hello, is it just when you are going slow and over bumps? Or does it also happen when turning?
    Hard to tell without seeing it in person...
    Is there a possibility of a video?
  4. #3
    Could be a wheel bearing that needs replaced
    Premier Member McGarva7's Avatar
    Aberdeen
    Possibly a CV joint if its when turning
    North East Scotland - Aberdeen
  7. #5
    Quote Originally Posted by McGarva7 View Post
    +1
  8. #6
    Leeds
    shock might of gone
  9. #7
    Chester
    It also sounds when turning… I will try and get a video tomorrow and upload it. Probably will be hard to pick up the sound when driving but ill give it a go!
    The noise is from the back wheel so I'm guessing it won't be a Cv joint?
  10. #8
    Quote Originally Posted by alexrogers View Post
    I would get it checked to see if a week bearing is done. Bring it to your local garage, get them to have a drive, they won't charge you for having a listen... Best/worst case scenario is they will be able to tell you what you are hearing
  11. #9
    Wheel bearing*
  12. #10
    Wirral
    Wont be the Cv joint. I can 100% as its the rear wheel :lol:
    More like a spring or shock thats gone
  13. #11
    Erith
    Is your spare wheel and jack secured properly? Are the rear seats folded upright properly and is the rear shelf clipped in properly. Also is it a 3 or 5 door, if its a 5 door, give the rear door hinges a good lashing of white grease from a spray can, they knock when they're dry. Other than that, I'd be checking for springs snapped/dislodged or worn rubber mounts. Check the bush on the bottom of the shock at the axle, check the shock is secured properly at the top, is the shock leaking? If it is change it. If you can, check that the rear axle bushes where the axle join the chassis aren't worn. Give the wheels a good wobble and shake make sure the bearings aren't loose/worn. Wheel arch liner, is it secure? Bumper is it flapping about on a broken clip. Exhaust, are the rubber mounts worn?
  14. #12
    Chester
    I've found the source of the knocking and its actually the front of the car. The Drop links from the anti roll bar have play in them, i'm gonna replace them asap, but I'm trying to source some original GM ones.
    Any one have any idea how much these are from VX?
    Thanks!
+ Reply to Thread
