2008 built corsa d. Opcom won't fully connect to easytronic
Results 1 to 2 of 2
Thread: 2008 built corsa d. Opcom won't fully connect to easytronic
    Hello all, I have my sister inlaws 2008 built, 2009 registered z12xep life, runs fine (now), but the clutch fluid is as black as coal, when I connect my opcom to the car, I can read fault codes from the tcu, but that's all, no other function, it just says "ecu negative answer to block request".
    Like I say, the box works fine, but I can't get the clutch bled
    Any help would be much appreciated.
    Thanks
    Allan
    No one have any suggestions of what might be causing this?
    Similar Threads
    1. Corsa d 1.2 easytronic 2009 retrofit cruise control
      By lakis84 in forum General Chat
      Last Post: 25-09-2016, 15:47
    2. Corsa 1.2 Easytronic Idle and running problems
      By chris966 in forum General Chat
      Last Post: 05-07-2016, 20:20
    3. App Radio won't connect to Bluetooth
      By Payny_01 in forum ICE, Electrics and Lighting
      Last Post: 08-09-2014, 20:55
    4. Easytronic Reverse Light Switch
      By royconverter in forum Mechanical
      Last Post: 15-02-2012, 18:22
    5. hi i am owner of corsa d 1,2 easytronic
      By aerox high end in forum Mechanical
      Last Post: 22-12-2011, 10:01
