Hi, new here I have a problem with my missus 1.3tdci, in 3rd 4th and 5th once I get to 3000rpm that light comes on and won't go over 3000rpm, but when I plug in it says no codes, any ideas what it can be?
Odometer Speedometer Trip computer Car Tachometer
Telephony Communication Device Mobile phone Portable communications device Gadget
I cannot advise on your current problem but please rad this before you have more -
Get it plugged into something decent that us capable of reading the codes that WILL be there. It is dropping into limp due to a fault and illuminating the spanner light because a code has been set.
A decent OpCom, Vauxcom or Tech2 unit will pull the code off.
Hi, new here I have a problem with my missus 1.3tdci, in 3rd 4th and 5th once I get to 3000rpm that light comes on and won't go over 3000rpm, but when I plug in it says no codes, any ideas what it can be? View attachment 21363
Hi mine doing the same so if you find the problem please post , I was told it could be a faulty egr valve ,as it came up on faults plus 02 sensor came up .
