Hi i have a 1.7 corsa d 2012 and i have had a problem with it where i was driving it and it suddenly went abit lumpy so i turned it off to try see if re starting the engine would fix it but the car hasn't started since sometimes you can get it running with easy start sometimes not. i have checked that there is fuel to the injectors which there is and i have had the injectors checked 3 of the 4 glow plugs work which i think wont really effect the starting too much as it wont start when hot when i do get it running. i have checked there is compression and also fitted a new crank shaft sensor and tried a new egr any help would be appreciated. ( there are no fault codes) been to vauxhall specialist and they told me it was egr.
