My sons first car but as the MOT was due I took it to the garage but it failed as the headlights (standard I think) are working but are pointing too low and the adjusters in the engine bay will not work. As this is not my car I have no experience of the Corsa headlights.
So can anyone help me.
Which of the two allen key adjusters does up/down, the inner or outer?
Will I have to take the headlights out to refit or replace the adjusters?
I see there are adjustment kits on the internet but will that be the problem? Or will a set of replacement headlights be needed.
You adjust the position with the switch on the lower right side of the steering wheel
You have one at the far right for lightd, the one in the middle should be set to 0
