Looking for some help with a couple of issues on my 2014 Corsa 1.3cdti
I noticed on the drive home from work last night that I couldn't get the cruise control to work, had a quick look online and looks like it could be a number of things, faulty stalk, switch at brake or clutch etc hadn't had a chance to have a better look but on my journey into work this morning when cruising at steady speed in 5th gear on the motorway I kept seeing the "shift" light, it would disappear under acceleration but would reappear when cruising, only problem is that I don't another gear to "shift" into.
Is it possible that these two issues are related?
Sounds as if you’re barking up the right tree on that, a code read from somewhere that has opcom/tech 2 would tell you more, given it has been working and isn’t now along with the shift up light says to me that the clutch switch is partly to blame.
Tbh I’ve just got into the habit of foot on clutch when I’m starting anything but I’ve been driving since I was 13 (farming) so after 31 years it’s instinct now but I’ll check when I leave work!
Discussion Starter · #6 ·
Well my friend, it starts with and without clutch pedal pressed so that’s possibly not the answer, still think it needs a code reader
Thanks for checking for me, I wasn’t sure if it could be started without depressing the clutch as like you I always do it out of habit!
Weirdly enough on the drive home last night my cruise control was working and the shift like was working properly.
