1 - 1 of 1 Posts
Hello fellow members, I have a 57 plate 1.3cdti with 125 k n the clock & it has been stood for around 4 months & it is now on the road again but when I go to set off it does not pull away as it should do but seems very sluggish as though you are in the wrong gear & then after a few seconds it will suddenly start to rev normally, it has had a good run round maybe 20 miles of me driving it hard to see if it would clear anything but its just the same. My son had a similar problem & it was the actuator rod that was seized up & my mechanic took it off which apparently is an awkward job & freed it off & its been great ever since which was 18 months ago. Could it be the EGR valve as the car was mainly used for short trips Any ideas please?
1 - 1 of 1 Posts
