I know some of you have audio set ups with thick wires but what do you use to strip them!?
I have some 8 gauge wire and i can find absolutely nothing that can strip it.
Put the wire on a flat hard surface then about half an inch from the end just literally saw at it then turn it around and repeat. Best thing is to do it bit by bit so saw abit then turn around saw it. Bend it on the cut and if you can't see the wire go deeper. When the wire is exposed all around pull the coating off the end with some pliers or fingers if you have tough hands haha
Yeah just use a knife m8 if you try and do it with snips or pliers you'll end up cutting into the copper, because its tri-rated its much softer than the usual copper cable
