Anyone had these problems with their abs light not going off when you start the engine code on obd 2 came up faulty speed sensor so changed speed sensor with new one still wouldnt go off when i started engine previously changed discs and pads for new ones . Tried everything to no avail even put it in local garage they couldn,t sort it and dread going to vauxhall main dealers starts off at £45+ then goes up to £200-£400 pounds for starters ? Can anyone help how to get rid of dreaded abs light at wits end😖👍
Give these videos a watch as could happen, but possible spring on handbrake maybe too to tight and causing it to rub. You will get it after watching the videos.
