just had mot was told abs knackered cost £500 or online £60 when braking getting grinding noise i have 59 plate corsa mechanic says common problem can anyone help also cheapest online abs ?
mechanic just said needs replaced when u look at near side disc it brown as brake not applying that side if that helps jakesween
Sounds like pump then. Pump wise I would make sure you get one made by the same company as I've had issues before. If you want to it cheap I'd be looking at the scrap yard.
