Hi Folks , looking for some advice about the heating system on my 2007 corsa (D) . I have been looking at all the posts on here about problems with the heater but unfortunately every one else seems to be having the exact opposite symptoms to me so please let me explain.
The most common issue with the corsa heating system seems to be the heater working on setting 4 on the swich meaning that the resistor is usualy the problem.
I have replaced the resistor twice and the heater does start working but only on setting 1 2 and 3 but not no 4 and the resistor gets very hot very quickly so the result is I keep burning them out .
I have had the fan out the car and cleaned the copper bit the brushes rub against also put grease on the bearing so the fan turns freely I am getting the feeling that the fan is OK. Would anyone know any other reason the fan would work on 1 2 and 3 but not on 4 and also burn out the resistior in a few minutes?? The wiring loom that goes to the resistor connection also looks OK as I have read about problems with the looms . Any ideas please let me know many thanks Alex
