ok i kinda understand, but i need a connector that goes straight into the pins in the back of the head unit and leaves 2 aux outputs dont i? as i want to wire the aux to the HU not onto the existing speaker cablego to halfords mate and tell them that you are putting the sub to your vx standard head unit and they will be able to give you the right thing all they are is an AOX cable with only one end with connecters and on the other it look like speaker cable :doublethumbs: just tell them you wire it to the exsting speaker cable.
So does the one end have aux connections, When i think of aux connections red & white plug connectors come to mind???, Then the other end is just bare speaker wiring which you attach to current speaker wiring???.
hmm ok so basically uv crimped or wrapped it round a bair part of the existing Speaker cable?you got it the the AUX from the sub goes onto that and the send that looks like speaker cable go on your the speaker cable. you do not tuch you HU
do you under stand
I do sort of haha, I couldnt do it mesell like, Ad blow mesell up!
If u can tell me the name and show me a pic of the wire right now, il go and buy itit dead easy onistly
I think its like that bt those white and red inputs need to be outputs and the other end bare?![]()
Im thinking of that type of wire but with the input side chopped off and the wire split and stripped then connected to existing wire. I think i am wrong haha, Really wrong:|
Thank god fusco i love you lol where can i get it? whats it called?You want something like this...
right kk thanksLol, I just googled "Vauxhall Aux Ouput" for a picture. I think that'sa VW one though. The black bit on a Vauxhall's much longer.
all i need is something tat will give me aux outputs from my head unit, but cant find itSo are you going to replace the one already on with the same one just connected up to new speakers/amp???
