I have a Cords D 1.2 the battery is not one of the no maintenance types so i was trying to see if the levels were OK, i can get the first three caps out but i need to remove the junction box to get to the others, can someone tell me if removing the junction box can do any harm i will not be removing the main positive lead as seen in the video just the junction box terminal strip which is held with a bolt as seen in the video at 1:20.
Thanks in advance for any help on this.
i replaced the battery last year on a 1.2 SXI .Did remove the positive terminal with the box attached.installed a BOSCH from TAYNA batteries without any issues whatsoever
Discussion Starter #4
make sure you remove the NEGATIVE TERMINAL FIRST before removing the positive terminal
Thanks will do also put negative lead on last when putting leads back on.
I saw a video of the inside of the black box it has two short lengths of cable and a big fuse.
Discussion Starter #6
I think removing both + & - terminals is probably best knowing my luck i would manage to earth the thing if i didn't..
