Bit of a strange one.... Fan heater blower works fine on switch setting #4 (i.e. full power - and by-passing the resistor pack). It doesn't work at all on the lower speeds - i.e. setting 1, 2, and 3. I decided to change the resistor pack anyway to rule that out... and the old one was fine - thermal fuse tested good.
Fuses: it's had this problem from when I first got the car. And I noticed that fuse F13 (7.5 amp) had blown. Sure enough, changing this fixed the problem - for a week or two. And then it blew the fuse. But after a third time, the fuse is fine but it still doesn't work. Puzzling...
Next step would be to take off glove compartment, front housings etc to expose motor and cable harnesses and try to do a bit of fault-finding. Circuit diagrams in Haynes are a bit cryptic (being polite) so will be resorting to working back checking lose connections.
Now i've read that the blower motors eventually start going tits-up and probably drawing more current etc. So it could be that it's on its way out - but if that was the case then i wouldn't expect it to work fine on full-speed setting #4?
Any ideas would be appreciated!
It's a 2012 1.4 petrol.
19839
R1 Front fog lamp relay
R2 AC compressor clutch relay
R3 Heated rear window relay
R4 Headlamp high beam relay
R5 Fuel pump (FP) relay
R6
R7 Fuel heater relay
R8
R9 Engine control (EC)relay
R10 Starter motor relay
R11
R12 Horn relay
R13
R14
F1 (30A) Starter motor
F2 (7,5A) AC com pressor clutch
F3 (15A) Diesel fuel filter heater
F4 (15A/30А) Horn
F5 (15A) Easytronic, automatic transmission
F6 (7,5A) Engine control unit
F7 (15A) Front fog lamps
F8 (30/40A) Engine coolant blower motor
F9 (30/40A) Engine coolant blower motor
F10 (60A/30А) Easytronic
F11 (7,5A)Diesel: Engine management
F12 (5A) Headlight range adjustment, Adaptive Forward Lighting
F13 (7,5A)AC/heater system
F14 (5A) Easytronic
F15 (10A) Head lamp high beam, right
F16 (10A) Head lamp high beam, left
F17 (10A) Engine management
F18 (7,5A) Engine management
F19 (10A) SRS control module
F20 (10A) Engine management
F21 (20A/15А) Main relay
F22 (70A) Central control unit
F23 (20A) Tyre repair system
F24 (15A) Fuel pump
F25 (30A) Anti-lock brake system (ABS)
F26 (30A) Heated rear window
F27 (40A) Anti-lock brake system (ABS)
F28 (40A) AC/heater system
F29 (20A) Cigarette lighter
F30 (7,5A) AC/heater system
F31 (20A) Electric windows
F32 (20A) Electric windows
F33 (7,5A) Heated door mirrors
I've just changed it for a brand new one. And still doesn't work on 1-3 :) Also tested the old resistor pack with a multi-meter and it's fine..
ma6be give this a watch. Be sure to look at the wiring c9ming fron the resisitpr also
