1 - 11 of 11 Posts
As above, just all of a sudden, push the button in, no sound and wont budge (just like when its locked)
Changed fuse but still nothin.
Any ideas apart from taking it to VX?
(yes I did unlock it :lol:)
climb in the back of car, lower the seats and look for a little plastic looking switch on the locking mechanism and press it, the boot opens.
wont help you for later, but it may free it, if not a trip to VX is needed.
ps, I take it you pressed your key more than once :p
IF its a fuse check both of these:
Glovebox fusebox listing:
6 - 15A - Unlocking the luggage compartment
7 - 20A - Central locking system
will look for that then cheers :thumbs:
yes i did press it many times lol, and yup changed both they fuses and still nothing :|
If you can actually get the boot open in some way, remove the plastic trim (think its just 2 T20 screws) as the switch may have disconnected from the loom.
if it turns out you need a new electro-button let me know as i've got one if you need one :)
Sorry to drag up and old thread,
I've just had this happen to me on my corsa d club. I see you've mentioned which fuses could possibly be at fault, but I've not got a diagram of which fuse is which in the fuse box. If it's not the fuse, where's this switch you mention, I can't see one. A pic would help please
EDIT
Haha,
found the switch and managed to open my boot. Now I can open my boot manually, I'll start the process of sorting the problem tomorrow. Could do with a pic of which fuses to check please. Thanks
EDIT
Haha,
Hey Ez just seeing how you go on with this. As a mate is having same problem?
Sorry for the late reply, You need to remove the rear handle and then take out the micro switch which is in the handle. I got another switch from a car breakers.
Cheers thanks a lot mate
1 - 11 of 11 Posts
