Apparently the guy who changed the battery said to me because the battery is dead , it can explode if you try to jump start it.I have done it few times with flat battery without any issues but maybe i was lucky. where does it say you cant jump start corsa d
I couldn't found the exact one as mine. These once are black, but mine from car has lights too.let us know how you get along with window repair
are you referring to these?they are preowned. so not certain whether in working order.you take a chance when buying electrical items from EBAY.I couldn't found the exact one as mine. These once are black, but mine from car has lights too.
Working nowAre you referring to these ?![]()
Vauxhall Corsa D Red Led Electric Window Switches / Switch Set (Clear Version) | eBay
Vauxhall Corsa D clear version front electric window switches / switch set modified with red leds. Other colours available white,orange ,yellow ,blue ,pink or green.www.ebay.co.uk
Yes those once, they are used, idk if they will work fine .Are you referring to these ?![]()
