looked in tutorials > interior > how to remove centre trim, but it seems to be that the user has removed the pictures from photobucket so i can't see them :( anyone else know where there is a tutorial?
Take the tweeter cover off and you will see a torx screw undo that and the clock section will unclip and unplug then you will see three more torx screws once you have taken them out the full top sectoin will unclip and come loose you will need to inclip the tweetee and hazard warning button then your done but remember to put hazard button back in dont turn ignition on when its unplugged hope this hss helped ya an good luck
