1 - 10 of 10 Posts
Hi all. My first post here.
1.2 Sxi
09 plate
Had the car for a week. Now refuses to start all fuses and relays working. Read all I can find .
Key on fuel pump primes. Engine cranks and smells of fuel
No spark. Checked coil pack. Read errors p0335 replaced crank sensor.
Still no start. I had spark but no fuel.
I bought a ecu kit and fitted it. Everything powers up but no power to coil . Used obd reader and live data sees rpm but fuel system when cranking went from ol to no-fault
Read codes now get
P0201. P0203. And an unusual
C2f64. I cant find any wiring diagrams to check wiring for faults
I know its probably been covered before but I am fed up with it now
Grateful for any help.
Anybody have any idea were I can find a wiring diagram ? Getting desperate
Steve
I think you are going to have to get a specialist to look at it all members here can do is guess on the info you have given, the fact you have said "pointed to an ECU problem" is a bit of a worry.
Download a Haynes manual, wiring diagram in there fella, sounds like a auto electrician job though as it’s been said above, we ain’t experts just armchair mechanics I’m afraid😉
Discussion Starter · #7 ·
Hi. Have bought a Haynes manual. But there is no coil or ecu wiring at all. anything going to ecu is not listed. Cam/ crank / knock/ map sensors. Nothing. But thanks anyway.
1.2 Sxi
09 plate
Read codes now get
I know out there there is a whole thread dedicated to Corsa D , it maybe C , ECU reprogramming. It is a whole specific sequence of things that requires some software. If you type in Corsa D (or Corsa C) ECU repgroamming, you may find the thread I am on about and be able to message some of those members , as a couple of them were quite knowledged in this area.
Which in itself, and this is said with the greatest respect to you, don’t **** with it as it will **** you back tenfold. And no, it wasn’t in a fortune cookie from the Chinese takeaway down the road! Please just get it to an auto electrician as they’ll sort it out far quicker.
1 - 10 of 10 Posts
