Hi bought the above corsa
As soon as you put the foot down it gets to 3000rpm the spanner light flashes and seems to go into like limp mode.
Had new egr value fitted and new alternator in last week.
Garage ran scanner no faults showing even after spanner has flashed on.
Any ideas on what it could be.
To me it seems to be as soon as turbo is suppose to kick in that's when the spanner flashes but I might be wrong.
Any info would be great doing my not in now
Cheers
First of all how long ago did you buy it and did you get warranty?
Strat at post #1 here and keep your fingers crossed it turns out to be something else -
Some more threads on the subject -
Hi I had a similar issue and when I had a look at the turbo the waste gate was jammed and wouldn’t close was constantly open. I lubed it up and used a pry bar and eventually it free’d off… also used a air line blower and took the air pipe off the turbo and blew through and eventually it ”pinged” and became free. Hope this helps as no real cost to it.
