Hi, was wondering if anyone could help I've been having issues with my cooling system I've spend a fortune trying to fix this, this list of parts replaced is
Bleed hose from tank
Thermostat
Thermostat housing
Waterpump
The temperature light keeps coming on and the engine management light, the only diagnostic coming up is overheating
Every time the light come on and pop the bonnet there is coolant all over the engine which I've been told is caused by the valve In the tank
I've had the head gasket checked and there isn't a problem with that the only problem is that the 1&2 setting on my radiator fan don't work have no idea what's causing this issue
Also when overheating all the pipes from the expansion tank are boiling hot and the pipe coming from the radiator to thermostat are freezing cold until you stop the engine the slowly start to warm up
Nobody seems to know what's causing any off this so hopefully someone might have had the same issues
Thermostat
Thermostat housing
Waterpump
