Hi All
I'm having an issue changing the air flow it wont allow me to change using the dial on the dash but if i put my hand behind the glovebox and manually move the control on the heater box it works and then i can use the dial to turn clockwise through the settings but it will not turn the vents back anti clockwise
any advice do i just need to replace it or is this something simple i'm missing
Thanks in advance for any help
Discussion Starter #2
Any help even how do i disconnect the cables i took the actual dials off for the fan control but could not take the unit out as the cables was holding it ?
Hi Chris I've the same problem with my corsa heater can you give details what was the fault and how you repaired it thanks
