Hello to all,
I would like to ask a few question about TPMS System. As you know, the TPMS system works very sensitively. For example, if the PSI value of one of the tires drops even one, it gives a direct warning. So my car is 2012 Model and doesn't have TPMS ECU and Sensors yet. However, I retrofitted ESP to my car and also my ABS Pump supports TPMS too. I've been wanting to do the TPMS retrofit for a while, but two questions stuck in my head are as follows:
1- Does anyone have TPMS in their car and can see its values/pressures on the GID/CID screen?
2- Are non-genuine tire pressure sensors functional? For example, 433 MhZ sold on Aliexpress
I am attaching the photo of the TPMS screen on the GID/CID Screen. To open this menu, it can be seen by activating TPMS from TID/BID/GID/CID settings with OPCOM or Tech2.
Thanks in advance for your help. Have a good day.
