21 - 28 of 28 Posts
Discussion Starter #21
I would still check the centre hole its much bigger than the side holes probably for a reason. (see 12 seconds into video)
Knowing my luck mate that'll be the problem I buy fix and sell alot of things and more often than not its something abit different to the norm haha if it was a motor bike dam it'd be done withing a hour 2 if I had to make my own loom 😂
Discussion Starter #22
Lil mk 6 fiesta was like a kinder toy rip it apart and put it back together easily it loved to breakdown 😂
Discussion Starter #23
Apparently if I find another ecu with the same model number copy my software from the ecu using mpps?? Which I already have, unplug my ecu plug in the new one then put the software on the new one.
So if it bricked the ecu it would be the one I bought anyways what you guys think the forum I was on he said he done it but was an audi a2
I haven't a clue if your method would work but if you are a competent spanner man this may be the less risky route -
Vauxhall Corsa D 1.3 Cdti Complete Ecu Kit Z13DTJ 55568383 KZ | eBay
This may not match your car but there are loads around.
Removed from a 2008 08 covered approx 98,000 miles
Ecu - 55568383 KZ ( must match )
Sdm - 13 262 361 BB ( must match ) PINK / GREY
Clocks - 13264272 EZ
Bcm - 13265078 GK
CIM - 13142283
X2 keys ignition baRREL transponder
No security pass
Make shore YOUR ENGINE ECU PART
NUMBER AND AIRBAG MODULE PART NUMBER MATCH OTHERWISE THIS KIT WILL
NOT WORK
20394
Discussion Starter #25
Bcm - 13265078 GK
CIM - 13142283
No security pass
NOT WORK
Yeah I seen this earlier but for the sake of a ecu off ebay for 35 quid and already having the software as I wouldn't care about bricking the new ecu and my old one will be sat out of the car with its software still on 🤔 a mad one but I'm willing to test it for you lads in future mpps isnt expensive and fairly simple to use haha
Discussion Starter #27
Apparently I can also get ur codes aswell the lads been getting them for people since 2014 I just open the software in hex format and look for the correct digits or summit he first learned it off the square astras or summit but there's a few helping people with it now 😊 hopefully it works mate ill let you all know and I'll also post his walk through onto here for yahs if it works vauxhall got a problem cause I'll do everyone I can free for any man to help out hahaha
Discussion Starter #28
There's a walk though on 1 of those pages to it but I'm waiting for a reply off a guy
21 - 28 of 28 Posts
