Was driving along the motorway and came to traffic when I stopped and try to put it into gear it wouldn't have it managed to turn the car off put in first and get it to the services waited around 10mins and got back in my car then the gears worked fine when I got back off the motorway and closer to home it wouldn't go back into gear again left it for the day went to work and took the car for a shorter drive and had no issues can anyone help cheers ken
Your gear linkage may need adjusting.
Take to a local garage to get it checked.
Cheers for response mate they've had a look and also are scratching their heads at the problems since that day I've had the issues driving to and from work and local driving the cars been ok but appreciate you help
Ideally you need the clutch and gear linkage taken out the car to identify what's causing the issue. I had similar issues a few weeks back when my gears suddenly went stiff in gears 1/2 and got specialist anti friction dry PTFE lubricant WD-40 and sprayed that into the linkage under the gearstick gasket and moved it around for 15 mins and became very loose to what it was.
It's either your clutch needs replacing or needs lubrication especially if there is none it will struggle to move.
