Good afternoon guys,
My son has a Corsa D 1.2 petrol (2008) and we have been trying to change the CPS. To cut a long story short, the sensor broke off and was flush with the block. It was really fused into that bore and I succeeded in picking out the plastic bit by bit and managed to get the cylindrical magnet out. That left only the outer shell.
Continued picking and eventually the remaining lower part moved and dropped down so it is now resting against the CPS target wheel/reluctor at an angle that I won't be able to lift it out.
Now, the question is do I push it so it drops down into the sump? The other thing is does this engine have the baffle plate under the crankshaft? If it does then we clearly have to drop the sump to retrieve this part.
Any gurus here have any ideas or perhaps have encountered such a fiasco - we have been at this for 3 weeks, whilst dodging the rain and 'confined to barracks' during Xmas/New Year.
Incidentally, I have removed the offside driveshaft for better access.
Thanks in advance for any suggestions.
Best,
Andrew
Best,
Andrew
