Hi,
I got a pretty nasty cylinder 4 misfire that resulted in a flashing engine management light, I have since replaced and checked the following,
4 x New Spark Plugs
1 x Second hand but newer coil pack that I know works
1 x Second hand fuel injector that works
Compression Test resulted in
Cyl 1 - ~175
Cyl 2 - ~175
Cyl 3 - ~175
Cyl 4 - ~175
These seemed a little too perfect, since its my first time doing a compression test I'm a bit wary I might have done that wrong somehow.
I get the following codes -
P0313 Misfire Detected with Low fuel
P0304 Cylinder 4 Misfire
I'm suspecting fuel pump or injector connector maybe but am stuck on where to look next, any help is appreciated.
Edit - This is a 2010 1.4L Petrol
4 x New Spark Plugs
Cyl 1 - ~175
Cyl 2 - ~175
Cyl 3 - ~175
Cyl 4 - ~175
