I had one when I had my diesel LE, defo recommend it, only ever kept it on the normal setting thoughIs this thing safe to use.
Any troubles with the DPF?
What settings do members run on?
I think the ones for DPF cars have a slightly different map. Email Andrew at DTUK and he should reply pretty fastIs this thing safe to use.
I think only when they read the ECU they will notice. They only do that when there is a serious problem. I would take it off when it goes in for a service to be safe. Also mine went into the dealer for a service and got knickedAlso do you know if there will be any trace elements when she goes in for a service.
Seriously? How much do they cost? I'd be so p****d off if that happened!I think only when they read the ECU they will notice. They only do that when there is a serious problem. I would take it off when it goes in for a service to be safe. Also mine went into the dealer for a service and got knicked
Sounds sweet! I presume it affects insurance and what not?It was £350 for a new one. Vauxhall Lookers paid out as I kicked off good style. 1 think you will notice 3 & 4th gear it will pull like a nasa rocket. Just love taking mine on a few twisty roads and letting the torque pull you about
Its does as you increase the BHP and NM Torque.Sounds sweet! I presume it affects insurance and what not?
Sent from my GT-N7100 using Tapatalk 2
