Hello my fellow corsa fleeks, has anyone done or know if I can upgrade my rear windows to electric operation on my 5 door, I’m guessing it’ll need tech 2 ing if I’m using Vauxhall bits and I’m fully aware of the holes that’ll be left in the door trims from the handles, but given they aren’t, as such, trim specific a set from an se should fit as I’ll need the rear switches and drivers door switch as an upgrade, be great to drop the windows when in range and get fresh air through especially with the weather getting warmer.
Had a look on autotrader and it seems you are indeed right, not on se’s or even on corsa e elite! Quite odd given they’re on astra j elites!
