Engine management light came on but car was driving fine. Disconnected battery a few times and light went off for between 20 & 120 miles, even managing to get it through an MOT. I have now changed both oxygen sensors but the light still comes on. Have been driving for a month with no issues, even with the light on, but have now started to get a slight loss of power for what seems seems like a millisecond, then drives normally. Starts fine and drives ok on motorway at higher speeds but seems to have a slight dip in power/judder around town. Grateful for any advice as to what to try next.
Neighbour had a cheap one that came up with bank one oxygen sensor and at time car was still driving perfectly fine. But light kept coming on had to take neg battery lead off to make light go off.but would still come back on after time sometimes 20 miles some times 120.today had engine judder or dip in power just for a second and the light was off then light came on after a few miles.
You need to find out what codes are stored take it to a garage that has a decent reader and get it scanned otherwise you'll be blindly throwing money at it trying to fix what you don't know for sure
You need to find out what codes are stored take it to a garage that has a decent reader and get it scanned otherwise you'll be blindly throwing money at it trying to fix what you don't know for sure is broken.
Thankyou for reply yes your right that's what l will do. Wish done it at the start now lol.becouse it was driving ok .and the neighbour said he had been driving with his light on for two years on his astra. Thankyou anyway will post what they say it is might help some else.
Had codes read today coming up with bank 1 sensor. Will put a new one on rather than the scrap yard one which what l have done. Can you use a normal 22mm spanner or will l need a sensor socket .
Hi corsa D 2009 mileage 117000 breather pipes blocked full of white porridge like goo. Car was running lump at low speed. Cleaned it all out car running ok now. But should l look for what caused it to block up. Or put it down to age and mileage . Any advice most appreciated Mac
Lol. Thanks for reply wonder if the thermostat stuck so water not getting hot enough to get rid of condensation but would of had some warning light l think. Miss not have a temp gauge to look at. Rocker cover gasket next job. Got slight leak .cheers Mac
Hi have watched a couple of vids on you tube. Some put silicon on the two joints near the timing chain some dont. Just wondering what l should do also is torque setting 8 any advice please mac
Corsa D 2009 1.4 fault code says bank one sensor. Which l think is one near engine at the front easy to get at. Vauxhall want £204 so looking for a cheaper one. Lost on line details of which position is bit confusing. Found one that says bank one position two . I thought position two was under car ?? Any advice please mac
Threads merged as this has been going on since December with threads posted all over the forum.
You are going round in circles you posted this in December -
Had codes read today coming up with bank 1 sensor. Will put a new one on rather than the scrap yard one which what l have done. Can you use a normal 22mm spanner or will l need a sensor socket (post #7 of this thread) .
Related Threads
Vauxhall Corsa-D Forum
1.3M posts
41.7K members
Since 2007
