Just wondering if the engine management light on is an m o t failure?
J Johnyd · Registered Joined Sep 24, 2012 · 84 Posts Discussion Starter • #1 • Mar 19, 2013 Just wondering if the engine management light on is an m o t failure?
rambo1984 · Registered Joined Jan 21, 2011 · 14,154 Posts #2 • Mar 19, 2013 Yes, any warning lights that are on are an MOT failures
J Johnyd · Registered Joined Sep 24, 2012 · 84 Posts Discussion Starter • #3 • Mar 19, 2013 Do you know how much it is to get it reset as it only came on when I put my decat on the car?
J Joel R · Guest Joined Jan 1, 1970 · 0 Posts #4 • Mar 19, 2013 Johnyd said: Do you know how much it is to get it reset as it only came on when I put my decat on the car? Click to expand... Will failt mot with decat
J Johnyd · Registered Joined Sep 24, 2012 · 84 Posts Discussion Starter • #5 • Mar 19, 2013 I know that but today I put my standard one back on and the light stayed on
AdB69 · Registered Joined May 6, 2012 · 47 Posts #6 • Mar 19, 2013 Disconnect battery , should reset and disappear unless there's other faults present
J Johnyd · Registered Joined Sep 24, 2012 · 84 Posts Discussion Starter • #7 • Mar 19, 2013 Il go give that a try
