Hi, I am looking to fit steering wheel controls to my Corsa D 2013 (1.3 CDTI If the looms are different) I know the illumination wire will be missing but is everything else there wiring wise and is it just a case of switching the wheels over and a bit of opcomm or tech2 and job done.
It is the most basic corsa they make the S model.
Can anyone recommend the required adapters I would need to use this with my pioneer evo62dab
Jake
Discussion Starter #2
Anyone any ideas on what wires I would need to run to make this work as I know the left side wont work but different forums say different wires
For anyone who is for some reason looking at this in the future I have found out from studying some wire digrams and looking on VX Owners Club you need to run a wire from pin 6 of the connector which goes into the black thing that has the indicator stalks behind the steering wheel to pin 50 of the BCM and pin 7 of the afore mentioned connector to pin 14 of the BCM Connector or somewhere you can find the illumination curcit.
In my case these wires were already present for some reason on my car.
Hope this helps someone in the future.
