This is what happened the first time now I'll try what you said
This is the bcm model number mate, my new relay never came today but when I turn on lights then press the front fog light switch on the control it shows on the instrument panel, does this mean its OK or will I still have to add that wire mate between bcm and fuseboxI'm glad! What is your BCM model?
Also do you know if my bcm has front fog lights
Yes, because "GK" have full option, you don't have a wire from bcm to fusebox? You have full stuff? Wiring from lamps to fusebox, fuse, wire from bcm to light switch?Also do you know if my bcm has front fog lights
So all I need is the relay which never arrived today btw🤬🤬🤬Yes, because "GK" have full option, you don't have a wire from bcm to fusebox? You have full stuff? Wiring from lamps to fusebox, fuse, wire from bcm to light switch?
did you have the original wiring to fog lamp?That's the relay in and they still won't work light comes on on the dash, the fuse and relay fitted but they still won't work
