Yes I have done it. And I have the part. I just don't know where the sensor is located in the carHave you done a scan to detect a faulty sensor ?
Thank you very much. When the fault came up it said neutral gearbox sensor. So I'm just wondering is there more then one sensor on it or not?i think the sensor is bolted onto the transmission casing.you have to access it from underneath the car. it can sometimes be difficult to remove.
check this video out . although it's not for a corsa it will be in a similar location
No it's a manual. Thanks for the help. Much appreciatedIs it an automatic gearbox ?anyway i am not sure because i have never had to access one on my daughter's corsa d
Neutral switches are usually found ontop of the transmission. This should be on top above the clutch fluid line. Have a look at the manual, should be able to detail for you properly.Hi guys, so my cruise control and auto stop start is broken on my corsa d black edition. It says the fault is a gearbox sensor. Just wondering does anyone know where that is located in the car. Would be a great help.
No not yet hopefully will get it looked at next week.Hi Jarlaith did you locate and replace the gearbox sensor in your car ?
