I’ve heard problems with the glovebox hinges are quite common. My glove box sits down slightly on the right hand side. The hinge isn’t broken, it just seems loose. Does anyone know if there’s any way to fix this? I don’t really fancy drilling the glove box and using cable ties, although if it’s the only way that works, I’d give it a shot.
Mine is the same it actual fell off at one point i found the hige plastic had cracked across the full hinge i managed to get it back on sliding the pins in from one end and i don't use it now,. i thin the only permanent solution would be a new or used lid.
