1 - 10 of 10 Posts
Hi guys. Can you tell me where te glow plug relay is for the 1.7cdti and can a novice fit it? I got the part and going to give it a try. Cheers
What is it your looking for exactly.
There is no specific relay assigned for glow plugs, there is a fuse in the fusebox under the bonnet. Its stated as
"F11 7.5A Glow plugs, ignition system(15A on some models)" Doesnt mention a specific relay that is assigned for them.
But if your looking for the glow plugs them selves I can tell you where they are.
Discussion Starter · #6 ·
Hello mate Thanks for the help :) I ended up not needing to use the module as the engine light wasn't reset after having the new glows fitted. Cheers
Cheers. I got a glow plug module it's like a little black box that plugs in? Cheers
Hello,
so, in the end, where exactly it was? And, could you tell me what engine type you have? Mine is A17DTS very cramped :( on this Corsa D chasis, and I do not know where it is hidden :?
thanks
1 - 10 of 10 Posts
