Just been reading a guide, so I thought I'd post the details up on here incase anyone's interested
The first digit of the code relates to the emissions regs the engine meets.
Z = euro 4
Y = euro 3
X = euro 2
C = euro 1
Cars made before the emissions regulations have no letter at the start of the code.
The next 2 digits are the capacity.
For example, the 20 in C20 XE means 2 litre.
The next letter is the compression ratio.
G = 8 to 8.5:1
L = 8.5 to 9:1
N = 9 to 9.5:1
S = 9.5 to 10:1
X = 10 to 11.5:1
Y = 11.5+:1
The next digit relates to the fuelling.
D = diesel
E = multi-point injection
Z = single-point injection
V = carburettor
Some engines have an extra code at the end, if they are different from normal
For example:
H = high output
R = increase output
T = turbo
V = volume model
B = IBC (Inverted Brayton Cycle, in laymens terms, the recurculation of gasses)
C = Corporation ignition system
F = Vehicles for Authorities
H = High output / Supercharging
I = Irmischer
J = Throttled Output
K = Komplex
L = Low output / Supercharging
P = Power Adapted
R = Increased Output
T = Turbo
U = Uruguay
V = Volume model
W = Venezuela
2 = Family II engine
Heres an extra added bit which shows what the last digit means:
The last digit on the end of the code will denote if an engine differs from a sister engine, is produced in another counrty, or any factory exra bits! As follows....
I = Irmischer
K = Komplex
P = Power Adapted
T = Turbo
U = Uruguay
V = Volume model
W = Venezuela
CORSA VXR Z16LER = Euro 4, 1598cc, compression ratio 8.5-9.1, multi point injection, increased output(189Bhp standard map).
CORSA SRi Z16LEL = Euro 4, 1598cc, compression ratio 8.5 -9.1, multi point injection, Low output(147bhp standard map).
Corsa D, tapping, only when warm? Videos now up on first page
Hi chaps.
I'm sure this has been asked, but this is a struggle finding an actual answer
I've got a 59 plate 1.4 16v with 65k on the clock.
Only just bought from a dealer who assures me this is normal, I know that it isn't.
It taps...
Hi folks!
I have a 2011 1.2 Corsa SXi. It’s done 101000 happy miles and up until 3 weeks ago was on its original clutch.
Being the kinda proactive type, I reckoned 100000 miles was probably enough for a clutch and the bite was getting quite high so thought I would get it replaced.
I usually do...
Hey Guys. I have a vauxhall corsa.D 2013 . I have Been watching.my.temp guage and I want to know what is our Operating Temperature in the cars.
Today I drove on motorway and it was at 99 - 101 / and then drive it back home on normal roads.and it.got.t about 101 103. I no these last two days...
Hi all,
Somewhat desperate plea
Corsa 07 plate 1.4 sxi
Usual story, car driving fine went to start up and nothing. Plugged into Delphi and getting B3925, B3929 and B3977 codes.
Battery wasnt flat at the time and have since fully charged battery and testing fine.
Checked all fuses inside engine...
