Anyone had problems with heated rear window only clears at top any suggestions
A few of the strips on mine don't work but i have never heard of a full half not working, have you checked to see if there are any breaks.
The silver infused repair paint works quite well if you use a fine brush to repair any breaks. I repaired 7 out of 9 of mine that were damaged 😢 successfully. Just build up several thin coats leaving them dry well before applying the next layer.
Sitting in the boot with the hatch shut makes it much easier to see what you are doing.
