1 - 12 of 12 Posts
Hi there,
Just wondering if any of you could help me with a problem I just had. My corsa D 2007 suddenly just lost power and accelleration and won't restart. I heard like a PUFF! In fact when I managed to get back home (towed) I found out a cable was hanging. Please see photo attached. Any ideas on where this would go and if I can just easily reattach it? Or would I need a mechanic?
Many thanks in advance.
yes if you find out which car component is attached at the other end u might be able to sort it out
Discussion Starter · #9 ·
Thanks both for your answers, for what I can see, the ends are the ones in the two pictures I have uploaded.
it's difficult to determine where the pipes are attached from pictures.
that's something you will have to work out yourself
In the first picture the pipe is hanging down below the bumper in the second picture there is no pipe on the connector so i assumed that was where the end of the pipe in the first picture connected, i was asking where the other end is connected.
Probably best to get a mechanic to have a look if you cannot move the car you may have a mobile mechanic in your area.
1 - 12 of 12 Posts
