1 - 9 of 9 Posts
Hi all,
Long time lurker but new poster here. Am guessing that quite a few of us now have pretty high mileage D's, and was wondering what might be a sensible mileage to expect out of it, given regular servicing.
I have an 07 3 cyl 1 litre (Life). Had it from new and now on 164800 miles.
Anyone else got high mileage models, and what issues have come up as you get >150000 miles?
Cheers
Hey cambs . I like this post should be a good thread if people get involved. In regards to hiw long you can expect it to last, i guess thats a matter of "is it worth" if it has a mjor repair need doing vs is worth more than the car you.may want to sell it, but also you cannot avpid any sentimental value it may have. I have a 2013 corsa D with 35k on the clock and its had new water pump, thermostat, radiator, and a few more things but the car us solid, i am believer that the higher mileage corasa should change to a thicker oil and also chamge the oil every 6 months regardsless , but if you can get 300k out of it why not lol
I have a Corsa D 1.2, on a 07 plate as well. Currently sat at 174,000.
Only had to change the rocket cover gasket, changed the coil packs to the 1.4 ones. New exhaust.
The only thing I need to really sort is the suspension since the shockers are terrible. Apart from that there is really nothing wrong with the engine.
Service it myself every 6k miles or a year which ever comes first.
Great thread
My Corsa is a 2013 CDTI and I am just shy of 150,000. I have it serviced once a year but I want to "treat" it and get all the things I need to get done on it.
I was thinking about doing a the usual air filter, oil and oil filter, but is there anything else such as gearbox oil that I can keep it running well?
Note, I have just changed the DPF, glow plugs and sensors as they call got clogged up recently.
Steve
Well it passed its MOT at 14 years old with zero advisories! Though I ended up needing a new line for the windscreen washer bottle that was leaking a couple of weeks later. Still, 186500 now are still going :cool:
Just goes to show, look after them and they’ll look after you. Mileage is only just over 13 k a year so apart from wear and tear you’ve not done bad, now if it was a 14 year old nova with that mileage, it’d be a different story! Progress is wonderful, but wonder how many 14 year old corsa f electric versions will still be running around with that mileage on?!
1 - 9 of 9 Posts
