If the radiator was blocked or partially blocked it would run hotter not cooler than the normal temperature of 105c how can it run at 80c with a blocked radiator?
This whole thread makes no sense to me whatsoever.
Just to reiterate, car developed overheating problem, using a lot of water over a few miles journey, showed it to many experts, two opinions pointed to its HG, but litmus test was Ok, so another said try new rad cap, so two new caps were tried, they did not make any difference, so one said remove its thermostat from the housing, this was done, car still overheated, so one expert said coolant is not flowing, he made that point on the bases that my internal heater matrix did not heat up the cabin either, so flow problem and pointed to a water pump issues, so this was replaced, the old one was perfect in fact, fans cut in very late so one opined that Temperature sensor may be at fault, so this was replaced with a new one, again it made no difference, so finally there was only one more thing left to suspect and it was a blocked radiator, it was diagnosed as blocked rad, this is when I ordered a new rad, but has not been replaced yet.
So instead I thought what is the harm if I try and clear up blockage in the rad by using what was available readily...Arial concentrated washing machine pods, what harm could it do? it is suitable for washing machines with aluminium parts so what harm can it do in a car? no harm in trying it since if it does not work I have got a new rad ay way, so from this point on I tried experimenting further to see if I can achieve cooling without removing or replacing the rad.
So I think you missed something, what I did was as an experiment and to buy some time, i.e. temporary fix the problem, first by using Arial Concentrated liquid detergent meant for washing machines, this definitely helped cleaning the radiator obstruction, may be not fully but adequately, then also by adding a 1kilo Ohm resistor across the Temperature sensor, which in cold state is around 1.6K and its resistance starts to decrease as the engine starts getting hotter and hotter, so when its resistance drops down to a very low ohms like less than 200 ohms, this is when the fan kicks in, and by this time the engine is already boiling hot and spewing coolant out.
So by adding a 1K ohm resistance your new resistance now becomes 1.6K ohms in parallel with 1 k ohm will give you a cold engine resistance of about 615 ohms, so you have a head start, meaning the ECU thinks the engine is already warm, possibly like 50c to 60c, when in actual fact it is still cold, such that when engine actually reaches 80c, the overall resistance is now just under 200 ohms and the fan kicks in and coolant starts to cool down by the fan, never reaching above 85c, so preventing it from boiling over with just the low speed fan running, but if the car was under load, then engine would build more heat and so it would then kick in high speed fan as temperature continues to increase and the overall resistance continues to decrease, when the engine cools down the resistance climbs up and fans shut off.
This trick did work for me, but but are there any consequences of running an engine at 85c as opposed to running it at 105c , I don't know, unless it effects its emissions control inn some way, only know when it is due for its next MOT
But as soon as I take that 1K resistor out, engine boiles over, coolant started to spew out.
Under normal idle conditions the engine is never in much load as it idles at around 850RPM, and in normal driving conditions the radiator is dissipating heat without the fan being required due to natural air flowing through the front grill when a car is in motion. So if this trick works for me I then do not really have to replace the radiator even if I said it is a temporary solution, all depends on its next MOT, if it fails on emissions it may mean the engine needs to run hotter then I will then have to replace it nevertheless and remove the external 1K ohm resistor I added.
I would have changed the radiator if it was easy without having to strip half the front of my car.
