LATEST UPDATE:
Overheating issues on my 1.4 Corsa Automatic.
to save you reading complete thread this is what I diagnosed and changed in order to get to the bottom of the problem in this order:-
1. Expansion bottle filler Cap ( Tried 3 new caps so far as being the cheapest option first)
2.Removed Thermostat altogether, ruling out any problems with it not opening
3.Noticed Fans were cutting in rather seemingly very late once the engine coolant had boiled out through the pressurised cap. Running dry.
4. Radiator fan blowing cold air, indicating radiator is not getting coolant flowing through it so could be water pump issues. ( However I overlooked the fact that once coolant goes out, water pump is devoid of any coolant then it is not going to pump anything, I learned this rather late)
5. Also suspected Head Gasket problems so had 2 sniffer tests carried out at two different garages. Both came with No HG issues.
6. Next I suspected Water Pump, since I was also not getting internal heater giving hot air either to heat interior, it blew cold air even when engine is just warm, so first the water pump was suspected not pumping strong, when that was replaced the internal heating still did not work.
7 So Internal Matrix blockage suspected and removed and flushed with a hose and cleared off any blockages, it then started to give out adequate heat for as long as coolant remained in the system, if once the coolant has spewed out it would blow cold air.
8. Finally thought it may well be the Main Radiator blocked, so had that replaced yesterday with a brand new one, still no joy. Bought another new filler cap, my 3rd cap.
So here is the latest on radiator replacement outcome:
Took the car to a garage to have the radiator replaced with a new one, also asked the mechanic to flush through the hoses and engine block, in case there is any debris and the new rad might become blocked as the old one was highly suspected to be blocked. (not proven but suspected that it was, so for the price of new one under £50, I chose to just replace it)
So after going for a test drive, engine overheated, coolant spewed out, warm air vents started blowing cold air, indicating lack of coolant and circulation.
So I am back to square one, no joy, car still overheating, so
bought a third new expansion bottle cap, and still no joy, fan kicks in around 103c-105c , by which time coolant has already spewed out so radiator has no hot coolant flowing through it to cool, as coolant level drops below the water pump impeller.
I had a new water pump supplied and installed by a garage, I was not too sure if they replaced the thermostat, so just for peace of mind 3 screws and I took the thermostat housing out, there is NO Thermostat so no question of thermostat not opening.
But if the fans cut in early, this overheating can be prevented, fans are under the ECU control and relies on Temperature sensor sending a reading to ECU, which fires fan relays. I can cheat or trick the ECU to kick fans in a bit early; by adding a 1K resistor in parallel, but this messes up cold starting as ECU thinks the engine is already at normal temperature so does not send extra fuelling. But once start, car runs sweet and cool.
I also looked at this thread
boiling coolant? so it is now evident there is a strange issue with these cars, this poor guy on this thread ended up trading in his Corsa with a different brand car, shame on Vauxhalls for running engine fans too hot.
In a pressurised system, engine does not have to run hotter than about 85c to 90c, that means cooling fan should cut in early, do not forget most Corsa's have a radiator fan switch which, most of these fan switches cuts in at 85c independent of ECU control, my Corsa has no radiator fan switch, so is under ECU control through a engine temperature sensor, so programmed incorrectly (in my view) to bring the fans on too late, since in most other cars fans cut in early, never seen fans cut in over 100c, My own other car a Vauxhall Calibra has a radiator fan switch, a two stage switch, stage 1 fan runs slow through the resistor, when temp hits 83c, and stage 2 fan runs at full speed when engine temp hits 87c, my Calibra never overheated, I bought this Corsa as my Calibra is now subject to dreadful King Khan's ULEZ Charge ! A Pathetic charge if you ask me. However, Vauxhalls must have got it quite wrong on this Corsa, switching fan on when engine is at 105C ! Bad Engineering.
( Incidentally, I brought the old radiator back with me, ran a hose through it, it has no blockage what so ever! ) The whole issue is fans not cutting in early enough to prevent overheating and coolant blowing out.) This is my conclusion, and fortunately I will be able to overcome this by adding some electronic sensing that trips fan relays in early and hopefully prevent these issue. and who knows Vauxhalls are aware of this and have modified fan switch on thresholds in their firmware in the ECU)
Lastly it could well be the Head Gasket.....who knows...
If that fails, dump the car outside the Vauxhall head quarters
( may be there is one more option, try a new expansion bottle ??? may be !)
Other Threads I will be now looking at:
OVERHEATING
TEMPERATURE SPIKE
OVERHEATING ISSUES
