You have removed the front face plate only, well done!
You need to remove the 2 bolts on the top, seen in your photo, then using a screw driver it should prize out. Hopefully that helps.
Also the procedure is documented in the Hayes manual for the corsa d, in section 3.8
thanks pal, I managed to sort it the other day.
