Aye up. I have a 63 plate corsa D that I’m changing the CD30 for single din. I have all the kit but need IL. On my old Astra H I took it from cigarette lighter. I’m think the same here but it won’t come out to I can access it. Is it just being more forceful? Also, which wire? Is there a spare like the H or not? Cheers.
This post is probably not in the correct section as it is tutorial,.......
but to answer your question you may take a feed off the 3 Amp fuse in the fuse box to feed your aftermarket radio. The 3 amp fuse in position F13 will provide a 12V ignition switch live source. This fuse is for the heated steering wheel. Use a piggy back fuse connector to connect to the fuse and wire separately. You should then power your radio with a 10 amp fuse in parallel to the 3 amp fuse. Halfords will sell this connection. You need a mini fuse piggy back connection.
Hope that is clear
