1 - 20 of 22 Posts
Hey guys, recently noticed my boot light is not lighting up when I open the boot.
I have taken out the light and looked at the bulb the filament is still intact (pics attached) so not sure if bulb is blown, b4 I start buying bulbs does anyone know what fuses it is for the boot light (see pics attached)
Any help would be great.
Discussion Starter #2
Ps does anyone know what bulb exactly I need if it does turn out to be the bulb? Thanks
I think they are called "festoon" bulbs.
Your old bulb should be stamped with the wattage you need so just search on that.
No idea on the fuses I'm afraid :(
Sent from my SM-N9005 using Tapatalk
Discussion Starter #4
Thanks again u33 u the man! L
Discussion Starter #6
No worries!
Sorry also mate. I've been reading about something called 'canbus' compatible lights. Do I need to worry about this for interior do u no?
No not if you are replacing with a normal bulb.
I think you just need to worry about that if you upgrading to led bulb...something to with them confuses the car, although I think you get can bus compatible led bulbs.
Not worth the hassle tho imo
I think the bulbs blown. You can upgrade it but honestly is hassle as Vauxhall’s have to be canvas free otherwise it could interfere with the car. I had to replace the fuse in mine but I can’t remember what fuse it is sorry.
Discussion Starter #10
Hey Dan
Cheers for input. It could be a possibility it's bulb but I don't think it is just cz I ca clearly see filament intact of u zoom into pic. That's shame.u can remember dpnu remember if it was fuse box in glove box / engine bay or boot?
I’ve got an 1.9cdti 09 plate Astra with only 85k on the clock fsh I’m the 2nd owner. It’s pristine condition literally
Hey Dan
It was in the fuse box in glove box I’ll try to find it now hang on
1 - 20 of 22 Posts
