I have a 2014 Vauxhall corsa and two months ago the car began failing to go into gear, there are no recognisable times when this will happen. I have done long trips and the car has driven fine and then the next day the car is awful to drive having to force the car into gear and it completely failing to do so. it has been to three garages the first said there was no issue. around the same time the cruise control no longer works.
the second ( a Vauxhall garage) found no issue but changed the linkage, the car still shows the same fault.
now the car is in the third garage another Vauxhall garage and they've changed the clutch at a handsome £1200.
drove it home and the car still had the same issue, I am losing my mind as they are saying there is nothing wrong when clearly, there is. the car is back in the garage but I am losing my mind.
I just wondered if this has happened to any body else.
